Re: Need info on a 101 fertilizer unit and a 180 planter
Posted by OB OBrien on March 15, 2010 at 10:39:14 from (173.20.211.36):
In Reply to: Need info on a 101 fertilizer unit and a 180 planter posted by dhermesc on March 10, 2010 at 08:45:47:
Hi Tom; There is a 14 tooth drive sprocket on each tractor. Other than that I have an assortment of sprockets. They have a slightly oval center hole and the teeth are slightly canted. I have; 3-8 tooth, 2-10 tooth, 2-12 tooth and one 14 tooth. Other than that there are two that fit together and are part of a drive clutch. I have another larger sprocket with 13 teeth and a locking set screw. There are other gears on the drive units in the pictures above. Some with 7, 12, 13 and 14 teeth. Hopes this helps figure things out. I have no idea at this time as what spacing the garden veggies will be. Maybe you know of a stabdard spacing that will work for most all plants.
Thanks for the help.
OB
