Re: electricity in the field
Posted by Wardner on March 15, 2010 at 14:28:50 from (4.154.233.93):
In Reply to: Re: electricity in the field posted by mkirsch on March 15, 2010 at 13:10:08:
The Electrall motor is a lot more "stout" than a C-60 engine as found on Model 55 balers. It is a farm service motor and rated for high overloads and high power/service factors.
As D Slater says, the Electrall generator is "live". Its output was turned off/on with a dash mounted electrical push/pull switch that controls the small exiciter generator.
As far as I know, only the belt pulley and cotton picker PTO are driven off the belt pulley drive gear. Elwood transfer cases also don't run off the belt pulley drive gear. Picture below shows the constant mesh Electrall gearbox. If the engine fan is turning, the Electrall is rotating.
third party image
Standby generation was not an afterthought. All the advertising I have seen cleatly includes that concept.
