I looked at my Operators Manual for the IH 140 and states the correct hydraulic fluid for the Touch Control system is IH Hy-Tran Fluid. There are other general hydraulic fluids that meet the Hy-Tran specs but I keep only Hy-Tran around for my Super C, 140 and SMTA hydraulic systems as noted in the operators manuals. Never had a problem using the correct fluid. Might cost a little bit more for the brand stuff but it is the compatible fluid for the entire system. Manual states the refill capacity is 6 3/4 U.S. pints for a drained system. An operators manual for your tractor is very valuable, hope this helps, Hal.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
