Re: Super A Farmall Wheel Weights
Posted by gene bender on March 16, 2010 at 04:51:27 from (207.177.56.155):
In Reply to: Super A Farmall Wheel Weights posted by Michael Bishop on March 15, 2010 at 09:26:12:
If traction is a problem then by all means put on both rears. They weigh around 145 ea. You can install them on the inside of the center section if you dont want the making the tractor wider.
