Re: International 3514 w/ 2500 Constructall w/ Exteneded ...
Posted by gurneejoe on March 16, 2010 at 05:19:24 from (205.188.116.73):
In Reply to: International 3514 w/ 2500 Constructall w/ Exteneded Boom posted by Matthew Palulis on March 15, 2010 at 21:23:47:
I would start by checking the pressure at each port of each section with a proper guage and snubber to make sure the pressure relief settings are correct. The valve bank may have been off for repacking and all of the reliefs backed off except section seven which could be acting as a remote relief to create enough backpressure to make the other circuits work. Each section will have a different pressure depending upon its function. Lift, crowd, curl, swing, etc. I would start with a 3000 psi guage.
