I've seen similar problems on many of the older IH hoes - with and without the extendable boom. IH backhoes with the dual hydraulic systems are different from any other backhoe I've ever worked on.
I've got a 3414 right now, with a 3120 backhoe. When it gets hot, the boom won't raise unless I pull steady on the swing lever. They are supposed to be two totally separate systems each with their own pumps - yet holding onto the swing forces the boom to work.
I suspect your problem is not because of hoses hooked wrong (but they may be also). I suspect that one of your pumps is bad, and/or you've got a bad check-valve somewhere. 3514 tractor uses one pump just for the power steering AND swing/stabilizers on the hoe. The other pump runs the front loader and all other functions on the backhoe. If one pump is bad, or, a check-valve goes bad letting oil from the swing-stabilizer circuit leak into the boom-curl-bucket circuit, you get some very strange problems like you've described.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
