Re: 2 Pre-cups/NBRs removed!
Posted by sflem849 on March 16, 2010 at 18:30:47 from (69.197.84.192):
In Reply to: 2 Pre-cups/NBRs removed! posted by Andrew Z on March 16, 2010 at 18:29:12:
Andrew Z said: (quoted from post at 18:29:12 03/16/10) Sflem, why are you pulling out the precups?
Andrew
The Central Diesel guy in Iowa said that you should pull them when you do the injectors. Is this wrong???
