You didn't understand what the machinist tried to tell you. He needs the diameter of an old or new sleeve to get the right sized repair sleeve. The block is bored out to press in the repair sleeve that has an interferance fit. (tight). Then the inside of the repair sleeve is bored to the same or a thousand or two press fit of the OD of the sleeve the piston runs in. Understand? If it was my own I know I will never wear it out in my lifetime so I would bore the repair sleeve to fit the piston & run it.That way the repair sleeve doesn't need to be as big either.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
