Re: 2 Pre-cups/NBRs removed!
Posted by charles todd on March 16, 2010 at 19:43:26 from (205.242.95.136):
In Reply to: 2 Pre-cups/NBRs removed! posted by sflem849 on March 16, 2010 at 16:33:10:
I pulled all 4 injectors on my Farmall 504's D188 and did not pull the pre-cups. Also, I did not pull the copper sealing washers per my diesel mechanic/injector man. He said as long as I did not "disturb" them then they were fine. I cleaned them and torqued them down. It runs like a new tractor.
Pictures of my 504 injector teardown...
third party image
third party image
third party image
third party image
I'm sure ya can tell which one was leaking. Also the injector man said since the ends of the injectors had a clean line around them that the copper washers were not leaking by. I replaced the injectors in the same holes, in the same orientation to minimize leaks.
CT
