Re: 2 Pre-cups/NBRs removed!
Posted by charles todd on March 17, 2010 at 05:50:15 from (155.130.107.20):
In Reply to: 2 Pre-cups/NBRs removed! posted by sflem849 on March 16, 2010 at 16:33:10:
Nice pictures. I see your injectors mount a little differently than mine did. Yours appear to be a two piece and mine were a one piece body. If your precups need changes, or other wise removed for some reason, this is how I was told to remove them. After you get the bosses removed, you can remove the head and then drive them out from the other side. good luck and keep up posted on your findings. What is wrong with your injectors? Leaking, low crack psi, or removing for head work?
CT
