Posted by Janicholson on March 17, 2010 at 06:34:13 from (199.17.6.222):
In Reply to: Hydraulic Pump posted by Two Banger on March 17, 2010 at 04:27:17:
Originally the PSI was in the 650 to 700 range Minus wear of the years. The relief valve pressure setting could have been upgraded to the 800 psi number, but only a pressure gauge will be able to assess it for sure. As the others have said, cylinder area, and mechanical linkages are the numbers to crunch. At high idle (wide open) the pump pushes ~6 GPM so it is not going to be radically fast with a big cylinder. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
