Re: 2 Pre-cups/NBRs removed!
Posted by sflem849 on March 17, 2010 at 06:58:58 from (69.197.84.192):
In Reply to: 2 Pre-cups/NBRs removed! posted by sflem849 on March 16, 2010 at 16:33:10:
Nope, I pulled the bone head move. I used precups and NBRs interchangably. The inector guys all call that big hunk of cast a precup. Not so much.
I am removing the injectors bc I am seeing a ton of crankcase dilution. When I go to bleed the injectors I wasn't getting a pulse from 2 and 3 and they were really black an oily. I took them in to a local tractor fixer and he cracked them. Two of them were opening WAY too low and the other two just put out a snotty stream.
