Re: Hydraulic Pump
Posted by IH fan on March 17, 2010 at 10:02:25 from (70.249.67.63):
In Reply to: Hydraulic Pump posted by Brownie 450 on March 17, 2010 at 04:27:17:
650psi with a 4" cylinder would be 8168#. If the pump is 6 gpm when it's a good pump, that 4" cylinder would move approx. 1.8" per second. I'd bet at 650psi, unless that is a near perfect pump, it won't move that fast. No load it would probably do that or a little better.
Had to figure this stuff all the time when I worked and built fixtures for hydraulic systems. Been retired for over 7 years, so it's fun trying to remember how to do it :D .
