Farmall Tractors Discussion Board
Re: 674 cool starting
Posted by JK MN on December 31, 1998 at 13:24:33:
In Reply to: 674 cool starting posted by al on December 30, 1998 at 19:51:44:
Al, Gas or diesel? If it is a gas pull the hose off the carb and be sure the butterfly completely closes. Adjust linkage if necessary. If it is diesel, do you put the "run/shut-off" lever in the start position? If you are not familiar with this position, look at the side of the injection pump where the cable attaches to the lever. There should be a small plunger that will push the lever just back from the full stop position. With the lever in this position, extra fuel is delivered to the engine for starting purpose and short warm-up only. Hope this helps.
Post a Followup
: Re: Re: 674 cool starting
