Re: Questions about F-series distillate tractors
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Regularman on May 04, 2000 at 09:36:20 from (147.160.180.17):
In Reply to: Questions about F-series distillate tractors posted by Paul Fox on May 04, 2000 at 03:25:07:
Your problem is not jets, to the best of my knowledge they were the same. The problem is either the float is set too high or the needle valve and seat are bad. Remember this tractor is different than others because it has a fuel pump. They are fussy about float settings and require a good needle valve and seat because the fuel is under more pressure than a gravity system. hope this helps.
Post A Followup
: Re: Re: Questions about F-series distillate tractors
