Something to keep in mind, if you have a turbo tractor it is always better to have the pump set a little "fat" or rich. When you take a nonturbo tractor and put a turbo on it you are obviously putting a lot more oxygen into the cylinder. When you are pulling and building boost you can create a lean condition which always creates extremely hot cylinder temps. This will cause pistons to swell, scoring cylinders, and maybe catastrophic engine failure. This wont happen immediately but I dont want to see someone learn the hard way. If it is a nonturbo engine, my opinion is that you would be pissing into the wind, waste of time. The engine can only draw so much air into the cylinder and injecting more fuel will give you little to no power addition but the smoke looks cool if you like to see your money drifting in the air. I have a bit of dyno experience and I like to get all the juice I can out of an engine without affecting longevity. Happy tinkering.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
