Unfortunately that is a typical symptom of scoring on the pump and motor plates.
The brass and steel plates, one of each for both pump and motor, must have completely smooth surfaces. There are oil passages in both plates to allow oil under pressure to pass through. A highly machined surface is necessary to cleanly cut off the flow. Any grooving in the surfaces allows oil to enter between the plates and the pressure will then force them apart causing the tractor (not engine) to stall.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
