Re: Farmall 806 Turning up or down the Power
Posted by komputatek on March 18, 2010 at 13:37:46 from (207.179.223.51):
In Reply to: Re: Farmall 806 Turning up or down the Power posted by dmiller on March 18, 2010 at 07:12:50:
My experience is with tractors under a dyno test. We could see measurable fuel consumption changes under a load.
I would think you would see some increase in fuel economy but would it be worth the expense of having it done right?
It"s easy enough to open the top of the pump and adjust the setting, but to do it so that you can measure the performance it should be connected to a dynamometer. Anything less it a guess.
