Re: Bull pinion and brake shaft seals
Posted by CNKS on March 18, 2010 at 17:40:44 from (216.144.104.128):
In Reply to: Bull pinion and brake shaft seals posted by Dave47M on March 18, 2010 at 17:34:29:
I answered this on the Restoration forum. Pull some more and you will break the cage -- Just pull or dig on the seal, carefully, whatever it takes--the seal will come out.
