Re: Temp Gauge on 46 H
Posted by Bob M on March 18, 2010 at 18:12:06 from (74.67.185.124):
In Reply to: Temp Gauge on 46 H posted by Illinois Farmall on March 18, 2010 at 17:52:37:
The temp gage is a sealed assembly. It's actually a pressure gage connected to a sensing bulb that filled with low boiling temperature working fluid. The fluid pressure increases with bulb temperature and the gage reports it as temperature.
Generally gage failure is from when the fluid leaking out. Only fix is to replace entire gage and bulb assembly.
