Re: gas to diesel '706
Posted by mkirsch on March 19, 2010 at 05:39:06 from (64.80.108.55):
In Reply to: gas to diesel '706 posted by cmathas on March 18, 2010 at 18:01:10:
EVERYTHING between the front bolster and the bell housing is different from gas to diesel. Frame rails, front and rear engine plates...
Early 706 has a D282, late has the D310 "German" diesel.
Is the D301 the bored-out combine version of the D282, or did you mistype?
Converting is a lot of work and a lot of parts, even if you fudge a few things and do some fabrication. To do it "right" is even more parts.
We had a D360 American diesel out of a bus put in a gas 756 several years ago. The mechanic used the gas frame rails so the tractor is now 1" longer and the hood doesn't fit without extensions. He also used the gas radiator, and the outlet is on the wrong side. The mechanic's son TIG welded up a cross pipe for the radiator, so the extra inch of clearance up front came in REAL handy. Power steering lines had to be extended. It looks a bit cobbled up around the bell housing area but it all works and it's solid.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
