Re: 240 steering gear
Posted by IH fan on March 19, 2010 at 10:46:11 from (70.250.253.104):
In Reply to: 240 steering gear posted by CJ_1080 on March 18, 2010 at 21:59:19:
Did you compare the gears with your old one? I believe there is a different faster gear ratio for a power steering model that would be harder to turn without power.
I have an "add on" Charlynn unit with a the slower ratio, so it works okay. I had to replace my gears last year also... seems to be a weak point with a lot of IH utilities. My only issue is it is run off the live pump through a priority valve and when the tractor is idled down, I lose flow to my 3 point.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
