Re: Converting IH implements to 3 Point Hitch
Posted by farmallhal on March 19, 2010 at 13:03:38 from (71.1.111.67):
In Reply to: Re: Converting IH implements to 3 Point Hitch posted by Chris Conner on March 18, 2010 at 09:54:03:
Chris, Per the post provided by MM_TX below the adapter you need is for the smaller fast hitch points with are 2 1/2" high. That is the size of the points on your 200 FH implements. You can use the larger fast hitch receiver for the 3" wide points but you will need 1/2" thick spacer bars to shim the receivers to retain the hitched implement. I think both fast hitch points are on 28" spacing between them. Good luck, Hal.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
