Re: Ever seen 4 glow plugs go at once?
Posted by jdemaris on March 19, 2010 at 18:22:02 from (67.142.130.12):
In Reply to: Re: Ever seen 4 glow plugs go at once? posted by Pat-CT on March 19, 2010 at 17:25:50:
It doesn't seem possible unless they were wired incorrectly. OEM has five hooked in series. Four in the engine and the other that works as an indicator in the dashboard. If any one of them blows, power is cut to all the rest. So, for four to blow when hooked up that way, they would all have to blow at exactly the same moment.
Those glow plugs are designed to run on less then one volt each (9/10ths of a volt to be exact). Having five in series keeps the voltage down low. If the wiring was changed and enabled a higher voltage to touch any of them, they'd blow instantly.
