Re: Ever seen 4 glow plugs go at once?
Posted by sflem849 on March 20, 2010 at 04:42:44 from (69.197.84.192):
In Reply to: Ever seen 4 glow plugs go at once? posted by Pat-CT on March 19, 2010 at 22:36:19:
Pat-CT said: (quoted from post at 22:36:19 03/19/10) Well hold on, I tested them actually with the power source of the glowplugs, The actuall wire that ppowers the glow plugs, Did i still blow them all? I also checked them with a test light before that with a test light and nothing happended?
A test light wouldn't do anything bc there is no power source going to the gp. You would need to use a MM and read continuity or even better resistance.
Not real sure about the tractor wiring thing, but it doesn't sound like sound procedure if they are wired in series. They would all need to be in place for the circuit to get hot.
