Re: Ever seen 4 glow plugs go at once?
Posted by jdemaris on March 20, 2010 at 06:01:11 from (67.142.130.44):
In Reply to: Re: Ever seen 4 glow plugs go at once? posted by sflem849 on March 19, 2010 at 19:55:56:
Not true. Especially with thermally-protected glow-plugs like Ford uses. Made by Beru and stuck into Motorcraft boxes.
Typical Powerstroke ZD-11 glow plugs is easily tested by feeding full voltage to it through an amp-meter. Pluges are wired in parallel and all get full system voltage.
Should draw 7.5 amps and when hooked to 12 volts, heats up to working temp in 7-9 seconds.
On the other hand, the plugs used in the IH B-275 and IH B-414 are only rated at 9/10ths of one volt and MUST be hooked in series and all five must be in the system. Four in the engine and one on the dash.
