Posted by jdemaris on March 20, 2010 at 13:49:05 from (67.142.130.27):
In Reply to: Diesel Fuel posted by Robertw on March 20, 2010 at 13:21:27:
Kerosene is pretty much the same thing as # 1 diesel fuel. It's thinner then #2 diesel that is used as engine fuel, has a lower boiling point, has less energy, and less lube.
Some winter-blends of farm-diesel are 1/2 kerosene in some areas. Also, JP8 military fuel is pretty close to kerosene.
You will get poorer fuel efficiency with kerosene and it will shorten the life of the fuel-injection pump if you use it all the time.
There are six classes of fuel-oil, 1 to 6 - but 1 and 2 are the only types usually seen at the consumer level. #3 used to be a lot more common and was sold as cheap "distillate" tractor fuel.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
