This problem happened thursday night, which at that time i did dissemble the front axle and the worm gear and steering gear look like new well not new but you get the idea, as for the wood ruff key it also was intact, is it possible my worm gear bearing race is wore out causing the worm gear to be back too far? making the worm gear spin the steering gear only the front splines which are taper making it skip? like i said the steering shaft and worm gear spin fine in conjunction with each other, i found a website showing the worm gear and it looks like it only has 4 rings as mine i thought atleast has more but i will have to look to be sure
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
