IH hyd cylinder
Posted by joe/pa on March 21, 2010 at 03:59:20 from (71.60.32.245):
I'm hoping that someone can tell me what I'm doing wrong... I've got a old single action IH hyd cylinder that I'd like to rebuild but I can't get it apart.
The bottom is welded, but the top looks like it should unscrew from the body. I've tried turning it but it only spins. Their is a small slit in the body up near the op where you can see what looks like a lock, and when the vent/discharge hole is lined up with the slot their is a gap. Any ideas?? I think the revision numbers are still readable...
