Posted by farmallhal on March 21, 2010 at 08:05:50 from (71.1.111.67):
In Reply to: 200 2pt to 3pt posted by clint s on March 21, 2010 at 07:41:52:
Clint, I've never used one and in fact never have seen one up close except in pictures. The way they would work is you would install the 3 point portion to the 3 point implement, install the top link bracket to the back of the tractor and then back up with the 2 point fast hitch to insert the prongs into the hitch receivers and attach the top link. Probably will need an additional person to assist getting it hooked up. I note you are asking about a Farmall 200 and guess you know those prongs come in two different sizes. The 200 takes the smaller of them as the receivers are sized to accept only the 2 1/2" smaller prongs. I am a real fan of the two point original equipment so everything I use with my Super C are fast hitch original implements. I do have an IHC 2 point fast hitch to 3 point adapter (never used it though) which is quite a bit different then the aftermarket approach you are looking at. It accomplishs the same task. They show up in the photo adds quite often but only look at the small point models for the 200. Hope this helps, Hal.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
