The fact that the engine was not stuck was a plus. Do verify that you have a spark. I suspect that it will run once you establish a spark. Do not hesitate to use starter fluid. For some reason, these engines do not like to start after long time setting up. Do verify that the valves are not stuck. A lot going on including new to unit carb as well as ignition problems. If there was water in the gas tank you will probably have to reline the inside. Make sure the fuel line is not clogged.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
