If the wter in the crankcase did indeed run down from the exhaust, you need to run a compression check. The only route it would have to the bottom would be through an open exhaust valve, so the stuck valves the others have mentioned are a real possibility. Any ting stuck in the head will show rightup in a compression check. If you find that, you'l need the hed off for work, and then would be the time to chek out the contdition of the rings and walss of the sleevesto evlauate what they might need. No more water than you found, they might be alright. sounds like a good project.
Holler for help if you need it, but let us know how it's goin' in any event.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
