Re: Farmall H hi/low transmission?
Posted by Andrew Z on March 21, 2010 at 14:27:14 from (64.252.41.103):
In Reply to: Farmall H hi/low transmission? posted by bradphoto on March 21, 2010 at 13:35:33:
What you are referring to is the M&W 9 speed. It gives you 9 speeds forward. The added 4 gears are between 4th and 5th. So it gives you approx 7mph-13mph in between the two gears. Otherwise you jump from 4th that is 5 3/8mph to 5th that is over 16mph.
So its pretty much a high/high not a high/low gearing like the Sherman
Andrew
