Re: cleaning up disk brakes
Posted by Andrew Z on March 21, 2010 at 14:32:57 from (64.252.41.103):
In Reply to: cleaning up disk brakes posted by charlie M on March 21, 2010 at 14:21:36:
You most likely need to replace the disks themselves as well. Any machine shop should be able to turn them for you, however if you need to machine the surface that mates to trans casting as well if you dont machine this then there will be too much free play in the brakes. AS for the advantage of them the have more square inch surface when compared to the band brake they replaced. The ball and ramp design also act as a basic form of a power brake. The down side to them is they tend to work well or not at all . Unlike the band brake where there is alot of grey area in there from good to bad.
Andrew
