Re: farmall a head gasket
Posted by mazemeister on March 21, 2010 at 18:30:33 from (24.188.81.230):
In Reply to: Re: farmall a head gasket posted by washingtonMark on March 20, 2010 at 19:45:38:
i had a leak right where the oil passage goes to the head. i sprayed the gasket with copper gasket sealant, torqued to 80 in 3 steps, warmed it up, retorqued, and good to go.
