Re: Worn Out Steering Cylinder On 1066
Posted by randy hall on March 21, 2010 at 19:34:13 from (209.143.0.64):
In Reply to: Worn Out Steering Cylinder On 1066 posted by Pete in Tejas on March 21, 2010 at 19:19:50:
dealer parts are high. the rod is $488 the seal kit is $82. i can get you a remanufactured steering cylinder for $400. plus ups.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
