Re: Converting clamp on duals to rims for M
Posted by mkirsch on March 22, 2010 at 05:43:20 from (64.80.108.55):
In Reply to: Converting clamp on duals to rims for M posted by CSK on March 21, 2010 at 12:08:54:
True, you could cut the "drop center" out of the M rim and weld it into the double-bevels... It would be some pretty fancy cutting and welding work.
IMHO it would be easier to widen the drop-center rims by splitting them and adding a band to one side of the center or the other.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
