Re: A steering
Posted by DAVE SHERBURNE NY on March 22, 2010 at 08:53:04 from (74.36.62.31):
In Reply to: A steering posted by Jim Isler on March 19, 2010 at 14:49:08:
A 1939 A will have the square ended steering shaft. All of them are worn so the steering arm is sloppy on the vertical steering shaft. The sector gear on the vert steering shaft has a key that wears. That's inside the steering box. The 4 tie rod ends are adjustable, take them apart clean them up grease them and snug them up. That steering arm on the bottom of the vert shaft can be shimmed with tincan material. Can you pull the steering wheel shaft in and out of the steering box? That can be shimmed. Check out this link for more on this subject.
http://search.yesterdaystractors.com/cgi-bin/fastsrch.pl
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
