Posted by sgtbull on March 22, 2010 at 12:33:51 from (163.191.228.254):
In Reply to: Cylinder Head Gasket posted by Tom in Iowa City on March 22, 2010 at 09:52:26:
There should be a crimped portion around the "fire ring" of each cylinder. The "lip" portion of the crimp should be to the head. The smooth side to the block. Sealers such as alumininum paint, Indian Head gasket material or Avaiation gasket sealer, (permatex product) all work well... just make sure you have it right the first time, and be sure to re torque the head after you've started it up and warmed up the engine. You'll be surprised how much you'll have to tighten the headbolts (or nuts) after its run a bit.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
