Re: Diesel 560 Hard Start?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by ltf in nc on May 24, 2000 at 11:06:59 from (206.228.214.253):
In Reply to: Diesel 560 Hard Start? posted by fordmustang on May 24, 2000 at 10:26:55:
Getting voltage to the heaters is not enough. The heaters must be working. They could be burned out. Kind of like turning on the light and the bulb is shot. Exercise caution in using the ether and the glowplugs together. I advise against doing that. If you are going to ether the engine have the battery in top charged condition and if you have a charger put in on the battery and when you are ready for cranking put it on boost. Once the engine starts turning spray a shot of devil juice into the inlet. If the tractor starts running fine. If it acts like it wants to run just give it enough ether to keep it running to see if the tractor can catch up on its on. If after a brief period it does not run on its own you are going to have to work on the fuel delivery system. Have you verified that fuel is being delivered to the injectors?
Post A Followup
: Re: Re: Diesel 560 Hard Start?
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
