Re: amp Meter
Posted by gbs on March 22, 2010 at 17:55:53 from (68.115.201.90):
In Reply to: amp Meter posted by Cory Smith on March 22, 2010 at 14:24:51:
the wire from the batt. terminal on the alt. goes to the ampmeter, then to the battery side of the starter. a simple way to determine which side of the ampmeter to connect the wire from alt.to is, to connect it to one side by it's self ,then connect the ign. and light switch to the other side, then turn lights or ign. on if it shows discharge your wired correct, if it shows charge you need to switch sides with the wires.
