Re: M Farmall steering
Posted by Loren MN on March 23, 2010 at 07:54:37 from (64.65.174.118):
In Reply to: M Farmall steering posted by Dan in Ore on March 23, 2010 at 07:44:00:
First thing you can try is opening up the gear box on the top of the bolster and turning the drive gear 180 degrees, if it"s a full gear and not a sector. There shouldn"t be much wear on that part of the gear. Also check wheel bearings and that the front wheels are centered on the hubs. Next thing would be changing the bushings in the bolster, top and bottom. I"ve done all that, and I still have a wobble on the road, so my next step is to change the worm gear.
