Re: 966
Posted by Owen Aaland on March 23, 2010 at 17:54:04 from (198.70.47.146):
In Reply to: 966 posted by Jim Cowles on March 23, 2010 at 15:15:40:
The 966 and 1066 are both 414CI engines. The 1066 has 12 piston cooling jets, the 966 has 6. The pistons and rings are different. The cylinder head is different. The water pump has an eight blade impeller on the 1066, four blades on the 966. (If the pump has been replaced there is good chance that it has the eight blade impeller installed.) The oil pump is larger in the 1066. The radiator is thicker in the 1066. 966 has a 12 inch clutch, 1066 has a 14 inch clutch.
