Re: 200 single front wheel - loading bearings
Posted by tractorsam on March 23, 2010 at 18:13:33 from (142.68.47.14):
In Reply to: Re: 200 single front wheel - loading bearings posted by Zachary Hoyt on March 23, 2010 at 17:59:40:
I don't know how to set up the bearings in a single front but here's what I would do. Disassemble and clean the bearings, repack them with fresh grease, adjust them up good and tight (until the shaft or wheel becomes difficult to turn) and spin the shaft a few turns to seat the bearings. Then slacken off the adjustment until it's totally loose (don't spin the shaft with the adjustment loose), then adjust them up until finger tight at most. This should give you a good tight bearing with just a little play (about .001-.005" which you may need a dial indicator to measure). Sam
