Re: 200 single front wheel - loading bearings
Posted by bodid1998 on March 23, 2010 at 22:08:03 from (63.245.245.5):
In Reply to: 200 single front wheel - loading bearings posted by carlsandberg on March 23, 2010 at 17:39:16:
deltared said: (quoted from post at 02:00:37 03/24/10) you must have a newer/different than mine.mine did not have bearings when i took it apart to chsnge the tire.
Delta is yours the solid cast iron wheel or the pressed steel one? Mine was the cast solid wheel with a cast bearing carrier that bolts to wheel center.
Dustin Il
