Posted by Haas on March 24, 2010 at 17:15:00 from (75.234.244.101):
In Reply to: super a plow set up posted by keith49 sa on March 24, 2010 at 17:03:19:
You turn the drawbar around and mount it on the front set of bolts on the final drives. The drawbar is then facing forward and the attachment point is about even with the front of the rear wheels. It's best if you have the draft control rod that goes from the drawbar up to the touch control arm. If you have that, you only use the drawbar with the pin on the brackets, removing the bolt that fixes the drawbar height. If you don't have that rod, you can rig one, or you can plow without it. You will have to set the drawbar in the lowest position and lock it with the bolt to tilt the plow down so the point will dig in. Once you plow a couple of furrows, the drawbar can be adjusted up to plow at the depth you want. I used one of these plows a long time with out the draft control rod. I just set the drawbar at the lowest point and then used the rear lift to keep the plow from going to deep. If you have thc control rod on the front it easy to adjust the tilt with the hydraulics. Also when you bolt the plow to the drawbar, you will use the outer most holes and the wheel dish will need to be turned dished in so the plow takes the proper amount of soil.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
