Re: Mixing viscosities
Posted by mkirsch on March 25, 2010 at 05:29:23 from (64.80.108.55):
In Reply to: Mixing viscosities posted by BruceS. on March 24, 2010 at 15:56:25:
If you mix the two oils, you'll cause a chemical reaction that will change the oil into an extremely caustic gel. It will bubble and smoke as it burns through the bottom of your tractor, the floor of your shop, and proceed to burn a hole clear to the center of the earth, and the rock monsters will escape to the surface and kill us all! Don't do it!
Seriously, it's all oil. If you mix two different viscosities, you will end up with a viscosity that's an average of the two oils. For example, if you add a quart of 140 to three quarts of 90, you get a gallon of 102.5, for all intents and purposes.
With an old M that's seen countless hundreds of miles of running up and down fields, a little thicker oil will not hurt a thing.
