300 oil pump shaft
Posted by KenB_Texas on March 25, 2010 at 08:16:36 from (216.82.216.252):
I noticed my 300 when warm had low oil pressure at idle. The idle is probably to low but so was the oil pressure (20 PSI). I have never had the pan off so I dropped the pan and pulled the pump. The pan and pump looked great no sludge or even dirty oil. BUT there was a lot end play at the top of the pump. I pulled the pump apart. The bottom plate shows hardly any wear but the shaft has a grove at the top. I didn't measure it but it is deep.
What do I do when the pump shaft is worn? Does anyone have new shafts? I thought because there were so many H's around chances are that IH would have one but they are no longer available from IH.
