Re: How do you tell which Fast-Hitch points are on an imp...
Posted by 504 on March 25, 2010 at 18:18:50 from (216.145.144.254):
In Reply to: How do you tell which Fast-Hitch points are on an implement? posted by Tim(nj) on March 25, 2010 at 16:21:10:
Small points are 1/4 inch shorter top to bottom, front to rear and side to side are the same.Things like three bottom plows are all big points,8 foot discs are big etc.
