Re: How do you tell which Fast-Hitch points are on an imp...
Posted by farmallhal on March 25, 2010 at 18:55:08 from (71.1.111.67):
In Reply to: How do you tell which Fast-Hitch points are on an implement? posted by Tim(nj) on March 25, 2010 at 16:21:10:
The smaller points for the Super C and 200 model tractors go into a receiver with a vertical opening of 2 1/2" and the receiver for the larger points have a 3" vertical opening. The points have the same vertical heights as well. I don't know if the thickness is any greater on the large points or not as all my implements are for Super C or 200 tractors. The smaller points can be used in the larger receivers with the addition of 1/2" thick spacer bars placed in the bottom of the receiver which were available from IHC when they supported the tractors and implements. Hope this helps, Hal.
